What are the numbers that flash on the odometer when you first turn the key on. it only last about a second and then it goes to the miles on the odometer. if you push the reset, you see the trip indicator.
I dont think so, I bought mine new & it flashed like 4550 ask the dealer if it was highest revs so we checked the down load,, nope thay wernt sure,, highest rev was like 2500..
Here' the sequence of events on a '07 K-9 when you turn the key on...
1. Needle goes from 0 to 50-60 and back to 0 (unless you turn it off then immediately back on, then it goes below 0 and back up to 0.)
2. Odometer window displays the pulse count set for the speedometer for 3 seconds, ~49440.
3. Odometer window displays the hours the bike has been turned on for 3 seconds.
4. Odometer window displays either total miles or "trip mode" depending on what was up when it was turned off.
The guy I bought my K-9 from (and apparently the State of Arizona!) didn't know this and when I got the title for my bike it said the bike had 49,440 miles on it!!! :loony:
