The road to the Phoenix
Also, stay tuned for the new condor setup for the ground and the quick hook up on the direct lift.
ChuckRB05
Everything's looking really good and those pipes! I didn't see it mentioned anywhere but are you getting rid of the ehc and re-wiring...now would be a good time to do it.
Picked up some chrome rounded pan head bolts for the mount setup.
I liked the rounded head over the standard allen
Just need to get a key for it or re-use BDM key (If I have to) The drag specialty key I have don't fit, because of the squared side on the coil mount.. but no biggie hopefully.
Cutter
Vulcan sells 'em, they were shipping the wrong ones from a new supplier, but I think they worked it out... I think Blitz and someone else got the story on that ?
http://vulcanworks.net/store_4/product.php?productid=175&cat=25&page=2
I ordered mine(same as yours, but different coils - plan to paint them with a blue hammered finish) about a month ago, and still haven't found the time to install.
(Too much crap goin on lately)
cavracer21
yeah the button heads provide a much cleaner look. i try to use them as much as possible. plus the heads are larger diameter so theres more surface to transfer torque load.
cavracer21
once i get my bike outta the trailer so i can tear it down, i plan on desigining a tubular motor mount and then come up with some sorta coil cover.
Yeah Cutter, I looked at that. But the problem I'm looking at is the key hole from the backside as well. THe top at the motor mount is blocking some of the key hole. I'm waiting to order a different key to see if the BDM one will fit.
Did you order the whole setup from Vulcan? My motor mount is a yankee eng. not a vulcan. Its not only chrome, but one piece.
Cutter
OIC... looking like you'll need to take a grinder to it...
Do you have one, I could bring one Sat ?...
seatmaker
Good idea, let's take turns with the grinder after the bar. Gas, you can get her home by then right?
Cutter
:roll: :lol: :roll:
I was thinking of pre-alcohol or loaning it to him... but that does sound like fun :D
Don't mind us Gas, jealously can give the best men wicked thoughts... :nono:
So you can't expect much from us... :crazy:
Yeah I'm not sure about grinding it. Its chrome!!! But I do have one if need be.
Got the Wizards renew, polish, and seal
The Doherty Power Pacc
And it goes well with the S&S desperato tear drop (sorry the teardrop is fogged over)
Rick
Gas sorry for the dumb question but whats the power pac do? i see it's a crab thing but thats about the extent of my knowledge on the product.
R
