TP Rocker Boxes
Chopper117
Chopper Nutt
I have TP Rocker Boxes on my 05 S&S 117. I was told if I'm going to do any performance I would have to switch over to S&S heads. Does this make a difference?
Shredder
Some have had issues, others have not. I have done performance mods and still have the TP boxes. No issues here (yet).
Shredder
Mach_1
I have the TP boxes, I haven't had a problem with them, besides the forward one the chrome is pitting. If anyone has changed thiers out and wants to sell them let me know.
BBChopper
Supports 2 Disabled Vets
Still have mine but no mods cam wise. Chrome sucks so I changed the tops and they just started a leak but I have all the gaskets all ready.
gearsmithy
Anyone who tells you that "any performance" will require S&S heads is not someone you should be taking advice from, especially when you asked them about rocker boxes.
I'll bet you meant rocker covers instead of heads since you already have S&S heads. :D
No problem with mine either.
Little-Boo
I do, they are in good shape, not new but well cared for. Make me an offer and will go from there
Carlos :whoop:
RRRUFF
No issues with mine except front cover chrome BD replaced. However this winter I am going to change my TP boxes over to S&S. The 05 117s are EPA motors and I am going to change out my smaller valves to stock S&S valves and maybe cam change.
twowheel99
The 2005 BDM models we're the bastard year (don't get mad, I know for a fact because I had one). The EPA made motorcycle mfg's do thing they didn't want to do. The 117 cid motors we're detuned so to speak, they had less compression ratio (taller cylinder heads), smaller valves (although they flowed pretty well on the low end), restrictor plates in the intakes (to reduce fuel flow), E series carbs (also to reduce fuel flow but helped on low end), a smaller camshaft (to meet EPA noise meters). Also for some unknown reason, BDM used TP rocker arms & rocker boxes (which turn into another headache for them) can you say warranty issues. Some but not all had issue, for example Raywood has allot of miles and no issues to speak of, yet I like many others had bad chrome, excessive noise, bad geometry, that lead to egg shape valve guides, broken valve stems, oil consumption, etc. I think you get the idea, your motor can be turned into a true S&S engine. It just cost money, as I said before it just depends on how much you want to gamble with your engine. Just as a side note, in 2006 after using up all of the BDM engines they went back to the S&S motors built to there spec's......
2
My understanding was they used the TP covers because they are quieter than the S&S and EPA is not only exhaust gases but noise too!
twowheel99
You are correct Raywood, different cam with shorter duration, and lower lift, adjustable pushrods, weaker valve springs, TP boxes and rocker arms, SuperTrapp highly muffled exhaust all to appeas the EPA gods. All in all it caused BDM a big headache and allot of warranty work to try and make things right with there owners........
2
