Tri-Bar Headlight
LDO
The Cleaner
For those of you with a tri-bar headlinght, you may want to check them. I found out the hard way lastnight coming back from Bike Night. Front headlight just didn't seem right. Felt like it was aiming low and I couldn't see CRAP!
Got home and come to find out, the plastic tri-bar attachment had vibrated loose and was sitting at the bottom of the headlight assembly. Took everything apart this morning and the screw holding the attachment was sitting inside the headlight bucket. Cleaned everything up and put some blue locktite on the screw.
Centered and cleaned everything up and she's good as new.
Just figured I'd make you all aware of the possible problem and you may want to just take it apart and put some locktite on it before you find yourself riding home at night with a disco ball for a headlight.:D
Its a good call for sure...
But I don't think the adjure's are the same way. The only 2 screws on the back of this setup are for the spring stay thing. As you can see in the pics below. Our tribar setup is somehow incorperated into the light itself...
