jbk641
Need Help,,,,,,
I just had a new custom stretched tank painted installed and painted. It has a single fill hole that has a metal tube from the cap (airplane cap) to the bottom of the tank which serves as the air vent. On the outside and bottom of the tank it attaches to a rubber hose that runs to the back of the bike to vent air is suspect.......After recently getting the tank painted and reinstalled I drove it around...filled the tank back up and gas sprayed out the sides of the cap....siphoned out a gallon and it stop spraying out....PROBLEM is that after inspection there is a small hole in the metal tube that runs from the fill hole to the bottom of the tank..Its near the bottom,,(an is not leaking outside or near the bottom). I followed this rubber tube to the back of the bike and there is a one way connecting valve seemed to be on backwards..cause when I took it off fuel came out and kept coming out...this is how I determined that there was a hole in the metal vent tube that is in the gas tank.......So,,,,,, here are my questions:
1. what is the one way connector and why does it seem to be backwards
2. How else can I vent the tank without venting out this metal tube that has a hole in it..
3. Is there a different cap that I can use that will vent without sprayin fuel out.
4. Can I drain the tank and somehow patch this small hole and what would one use to patch metal that will be sitting in gasoline constantly????
5. Is there another way to remedy this.....??
Currently the the vent tube would be draining my tank of gasoline if the connecting tube was turned around ( I tested this theory and it drained fast)
Also...the temporary fix is If I keep the tank half way filled it doesnt spray out and seems to find a way to vent out through the cap without issues...only a tiny bit of gas leaks out the cap.....
If anyone has ANY Ideas on how to remedy this please email me jbk641@yahoo.com or call 316-640-3439 ( I just did a a $2700 paint job so I do not want scrap the tank just yet)
Well, almost.
