not sure of the 'write up' but adjusting till unturnable sounds like the adj using limiters which i have. thats done starting with the tappet's piston bottomed out with valve pressure on it which forces all oil out. then 1 turn looser.thanks alot, thats how s&s says do it but the write up with pictures says extend rod till unturnable ill do it to a slight drag. ill go 3 and ahalf turns
