new rear fender
More fender or less fender
  • Total voters
    259
BIG HOUSE
DOG ONA DOG
Well the fender is still in the box:bang: after all of the input idk I want to cut it but b4 that happens it will have to have airride installed and a little worried about the repaint matchin so for right now its on the shelf at least untill winter.
BorgerBigDog
BORN TEXAN
I have a raw fender i want to cut but i am trying to come up with something diffrent this fender i dont care about the support for a passanger. Any cool ideas would be most welcome...:D Ed if you read this what about cut the fender on both sides like a jester hat then add the face to it you know your usual sick shit you have stored up there in that head of yours...
airbrush-ed
kustompaintbyed.com
Rob, the more you cut-the less you have for artwork. Can't have both, unfortunatly.
Big House, I could match your original factory paint. After all, I designed that paint job. No problem-Don't worry. Git-r-done!!!
Staffy
Reach out to Ron from Vision, he is a member here on the site. He does magic with metal.....check this out all from stock tins – All painted it is mesmerizing, your curiosity get the better of you is this a 3D fender or a paint job illusion….
http://www.bigdogbiker.com/forums/general/10525-project-peek.html
REMorris
OK Rider Shakey
If it was mine to do, I would seriously look at mounting the fender from the swingarm so you can get the clearance down to that of a hardtail. And then modify the seat so it mounts strictly to the frame (might require a different seat pan to have clearance on the moving rear fender).
Anyway, just my thoughts,
Richard
Chris04Masitff
Where did you get this done, I own a 2004 Ridgeback and would LOVE to have rear fender like your on mine.
Thank you
Lou
hey man i purchased bike like it is . Eric Warren Design in Tampa did work for previous owner.
cdogg556
Changing struts?
Does anyone know if I can run shorter struts from any other models so that I could do a shorter rear fender? I have a 05 bulldog and want something that shows the tire a little more, I noticed that the struts from a chopper look shorter, but I am not sure if they will work.
I would imagine that if you get struts from another bike that has the same frame as you then they should work as long as you have clearances which shouldn't be an issue either. May have to do paint over though.
RT to RT, DT to DT
cdogg556
RT to RT, DT to DT
Ray, how do I know if I have an RT or a DT frame?
vigilanty21
I was thinking about doing the same thing. I was going to shorten mine up. but I would also have to custom fab some struts to mount the rear lights. Just enough fender to have the seat back covered.
BadDawg Bill
Go too short and all the crap from the road hits ya in the back. Not very nice in the rain or on our sandy Fl. roads. Just something to think about...
