CRAZY JOHN
checked stator volts and got no reading at plug. bad stator huh?
Mongo, he won't have to worry about that. No compensator although the new BDM website states they started putting them back in on newer bikes now.Stators aren't that hard to replace. The hardest part is loosening the compensator nut and pulling the magnet off without pinching your fingers. I had to replace one on all three motorcycles. I did the last one in an hour and a half.
I'm not Ray but. The 05 and newer BD's have just a sprocket with out a compensator. The 09's have added it to all but the ridge back. You still have to remove the crank nut to get hte sprocket out of the way thou.what do you mean by no compensator Ray? Surely he has to remove the primary chain assembly in order to get to the stator?
Thanks Gas MasterComp sprocket
You didn't fall hard enough. At least at a hospital there would be a chance of waking up to see a pretty nurse instead of Baby Ray leaning over you!May sound stupid but also check your tester. Been there, (not bike related) knocked off a ladder on to concrete. Next thing I remember is Baby Ray checking to see if I was still breathing. I think he was hoping for my bike:bang:
You got that rightYou didn't fall hard enough. At least at a hospital there would be a chance of waking up to see a pretty nurse instead of Baby Ray leaning over you!![]()
I wondered the same. I have been told that the compensator reduces some of the shock. But really don't know. Also wonder why they are not putting it on the 09 Ridgeback. Offset due to 330 tire? Using up parts?Makes you wonder if they (BDM) went back to the compensator due to all the clutch problems?![]()
