I need a high flow air filter system
M
McLovin
Guest
I looked at the "intake thread" and saw lots of intakes, but I did not see what I want/need. I need a high flow air filter like a "Big Sucker" or "Roland Sands Air Venturi" for an S&S 117 C.I. I found stuff for a harley, but the bolt pattern is different. I tried a velocity stack, but it would'nt tune right with my XXX carb. (Talked with Bob, he said ditch the velo stack), put the stock cleaner on and it runs super fine. I just wanted something different that actually works, hav'ent had any luck with spike type filters, they don't flow enough air. Also, there was a thread about a digital speedo/tach, and I can't find it now, I wanted something digital because 500 RPM increments (stock) is not good enough for fine tuning.
Tanks fo any hep!!
:choppersmiley:
Nothing better than the stock S&S unit. Proven over 50 yrs and copied by many!
If anything add a K&N filter to it or even get the extended kit for it.
Oh and if Bob told you then there is no one more qualified to answer that!
M
McLovin
Guest
Thanks for the reply Ray, I was hoping for something a little different from stock, but that's OK, 'cause like I say, it works great! (I did add a K&N filter).
What about the speedo question, do you remember the thread that Jake or Nelson started about the digital unit, or do you have any suggestions?
Thanks man!!
M
McLovin
Guest
Yeah!
That S.O.B. does look BAD ASS!!
I may go with a setup like that...
Thanks man!!
Sorry not with your setup or wiring. You would have to rework all your wiring.
If you can hold on BDM is coming out with a new unit that is not made by Autometer and is not subject to the same problems or fogging. It has a real time tach too. It will be retrofitted to all our 04 and newer bikes.
I hope to have mine soon:
ray, you say it will be a retro-fit. are you aware if it will be an owner purchase or covered under a service bulletin?
I am under the impression that it will come out of our pocket to upgrade to it.
I will try and find out for sure though. :cheers:
This unit that our forum member cutter has from gates performance is no slouch either. I would like this unit myself.
