ChevroletSS1965
I just picked my 2003 pitbull up and I absolutly love the bike (I'll post pics soon), but there is one problem the speedo doesn't work. The bike has the black autometer big dog speedo. When riding the needle stays at zero 95% of the time, but after days of not working the needle will jump for a couple seconds then back to zero while riding. I searched through all the old threads to see what the problem could be. I keep the bike on a battery tender at all times when not in use and it has a big boar battery. When I turn the key on the needle sweeps to 60 then back to zero and the display flashes 49438 for a second. After reading on the forums I found out that number is the speed sensor pulse number. I pulled the speedo housing and unpluged the speedo to check for corrosion or cut wires and everything is fine. I pulled the speed sensor and wiped it off and still nothing. I figured I would try to recalibrate the speedo, but when I follow the instruction by holding down the button and turning the key on, the needle sweeps to 120 and stays there with a 0 on the display. If I push the button again the needle goes from 120 to 60 and stays there with 0 still on the display. If I start to ride with the needle at either 120 or 60 the dispay still reads 0 while riding. If I continue to ride the 2 miles and stop then push the button again the needle falls to zero then sweeps to 60 and back to zero with 49438 on the display for a second just like if I was starting the bike normally. I never see "-_-_-" or "0------0" showing that I'm in calibration mode, just the needle froze at 120 or 60 depending on if I push button once or twice. I have the old style ecm so I can’t re-flash it. Not sure what else to check or if the speedo is just bad. I hate to buy a new speedo and then it not work either because there is something else wrong. Sorry for the long post
, but I just wanted to be detailed. Any help from you experts :up: would be appreciated. Thanks
-Taylor
, but I just wanted to be detailed. Any help from you experts :up: would be appreciated. Thanks-Taylor
