PitBull is dead...help
EODMB
Any advice on my '05 Pit not starting? I have searched the "post", (great post btw) checked everything I can think of and am still my wits end. :confused: Any suggestions?
Mitch
"EODMB"
Chopper Dave
SIICK!!!
Mitch....ya have to tell us a little more than just not starting:confused:
like...what does it do? does it click? turn over? nothing...etc.
EODMB
She turns over fine, getting fuel but acts like she isn't hitting. I had her running a couple days prior. It was slow to start the last couple of times (battery was low and needed replaced). I replaced the battery just yesterday (310 CCA) and now she just won't start.
Have you verified spark at the plugs?
Are you flooding it out?
Do you have gas in the tank?
Are you keeping the throttle closed when attempting to start it?
Pull your plugs and tell us if they are wet with gas or fouled or dry.
EODMB
Looks like I'm not getting any spark at the plugs. Coil problem or EHC? Any thoughts?
Thanks everyone.
Thanks everyone.
There is three wires on the back of the coil. Check to see if one of them broke off. It's happened to me before as they are small and fragile.
EODMB
The Dog is Barking!!!!
Raywood your the man! Found a loose wire on the coil, fixed it and she hit immediately. It's sunny and warm...gonna go put some wind in my face.
Thanks Raywood.
Mitch
Thanks Raywood.
Mitch
:cheers: :cheers:
Slider
Not a bad idea to pull the coil once in a while and look in the female connector of the coil. I had a prob starting and the inside of the coil was black with carbon from arcing. The other connector was fine. Cleaned the connector and bam ran fine.
