anyone ever install these? (Spiked GunnerBig Dog Motorcycle Hand Grips Black Gunner)Followed Gas' instructions but the throttle grip is loose and the metal on metal is "sticky"...I need some help over here...
Exactly... I believe I even covered this in my grip swap how to.my xoproxox grip was sticking to when I first installed, removed & installed a little greese on bar works great now
I was about to order from these guys ... are your grips over sized? They look great ... there should be solution for the stickiness ...![]()
Ok Diesel... I understand that. Oscar makes a good point. I had mine stick once. The control unit was on kinda crooked. Be sure to back out that set screw for the controls before you tighten the 2 halfs over the grip. Also be sure that the farrels are in good.Gas, I use quite a bit of company ink printing out your how to's. I followed it to a "T". I will say I was a bit light on the grease since you can literally see through these grips to the bar...
Frank!I did them a while back ago and the left was loose. The thing to do is look at your old stock BDM grips. Inside the stock grip is a round clear plastic liner - pull it out. You may have to use needle nose because they are lighly glued in. Insert that liner into the XO grips and it will fit perfectly...
were have ya been dude?I did them a while back ago and the left was loose. The thing to do is look at your old stock BDM grips. Inside the stock grip is a round clear plastic liner - pull it out. You may have to use needle nose because they are lighly glued in. Insert that liner into the XO grips and it will fit perfectly...
