On a LSD it shouldn't be too much of an issue. If you want to reduce the gap left from the belt then you might get a thinner inner primary.
Oil is the only down side I can see. Can be messy.
Kinda funny reflecting on my "Sailors Story" back then we were trying to get away from the chains.
I talked to Baker and they said it would be an easy transition.
As far as oil goes, chains have come a long way since back in the day is my understanding. Most good ones are ringed (sealed) to a certain degree to maintain lubrication longer.
The past couple of weeks have been tough to own an older BDM.
It took quite some time to get fork seals and bushings figured out. Very few dealers have their parts systems update back that far.
Bought (5) 6205 bearings from Napa ($25 each) since they were the only ones that had them in stock. Pulled the front wheel off to find Timken bearings. Back to Napa to return the 6205's and get Timkens. They had the races, bearings and 1 seal. Ordered 3 more seals.
Pulled the rear wheel and found 3 6205's.....:loony: Screw it, ordered 8 6205 bearings online $36.11 shipped. Here by Friday.
Waiting for my buddy to come over and pick up some aftermarket pulleys that needed the ID's milled to fit my PM wheel hub.
Decided to pull my forks so I am ready to go when I have time to replace the seals/bushings. One of them got hung up in the clamp on it's way out and cut all to shit in a spot that is NOT covered up.:bang: :bang: :bang:
I spent 2 hours trying to sand out the cut and to deep to get it all out.
Of course the pulleys I have to substitute my $650 PM pulley because it squeaks are too thin to just open them up unless we fabricate a hub extenstion to maintain surface pressure.
Fuck it....pack it in for the night.
Decided to call Full Throttle in Michigan and talked to a guy named Jeff. Would recommend him to anyone. Had the info I needed even though I did not like the info.
Asked him "How much for a single fork tube"?
Can't buy 1, have to buy the whole assem. $1600......
What if I need to replace a slider if the bushings were to worn?
Again, can't buy just a slider. $1600........:angry:
The thing is I love my bike even though I am having so many problems on shit that should be basic.
So instead of getting bent, just looking for ways to keep it on the road that are reasonable.
Either way, credit this site for the knowledge and member willingness to help anothrer rider out. :2thumbs:
