Need some spacers
LDO
The Cleaner
Would like to space out my brake and shifter pegs out a bit more. Need a spacer that is 7/8 od, a hole for a 5/16 bolt to pass thru and needs to be 1 inch long/wide. The other needs to have same measurements but 1/2 long/wide. Already checked gardner westcott, chome bolt.com and bolt depot.
Anyone have any ideas????
Muchas Gracias for da help-o....:D
Moespeeds
I've got mine spaced with some chrome Harley spacers I found in my junk bolts box. No idea where I got them. I also had a spacer made to space out my entire forward control on the right side. Had it done at the machine shop for $40, and all I had to do was polish it.
LDO
The Cleaner
Hey Moe,
yeah, I looked in my junk bolts box too and it was empty, you must have gotten them!:D
waykool
Banned
What are they worth to you?
waykool
Banned
I'll be your best friend...:D :D
Haahahaha...... :D
I think that I have the spacers you need here in my hand. They are made of billet aluminum and polished to a mirror finish. One is 7/8" OD x 1" and the other is 7/8" OD x 1/2" both have a center clearance hole cut for a 5/16" shoulder bolt. Will this work for you?
