That is a tank off of a Chopper also used on the Mutt and the new Coyote.Actually it helps a lot because now I know what this bolt pattern will bolt up too. If I re-sking this tank then I know what it will bolt onto.
Oppps, forgot to mention in my earlier thead that the Ridgeback is included or at least up to 07.I think the 05 ridgeback has a tank like that also.
The sticker says .......N5740In the lower right hand picture of the tank is this a part number?
yeah....here are a few shots of my K-9 tank....That sounds like a project number... call BDM they will tell you.
Further I would venture to say a chopper tank for sure. I have saw all of them in person..
K9
the mounts look the same..
but the shape isnt, here's a shot of the front angle of the front of the tank
maybe Dave or somebody can put up a better pic of the top... not the same shape as yours.
Yea it is a lot more squared off and the mount wells appear to be more shallow then on the K9.See the front end "roundness" of the k9 tank isn't on those tins.
Vision, some of the models are very tight. Here is my 05 and it doesn't have much clearance. I remember back in 05 and 06 they even had some issues with interference and ended up painting a bunch of tanks.Yea it is a lot more squared off and the mount wells appear to be more shallow then on the K9.
Cool so if we know we are working with a chopper tank should it fit any year or did they have different configs withing the model?
Gas- From the looks of your pics it seems like there is room to take the tank up taller a few inches without hitting anything. Whould that be a fair statment or am I just not seeing things from the right angle?
