2009 Bulldog
tommyboy
This is why i love this site the people with connections help us that dont.I like it!Anyone know when dealers will have one?
Dakotabos
I WANT ONE
Retirement gift from Tanya:whoop:
But I have to get her a RV 1st
Nomad2day
Longhair Redneck Geek
Can i put that fairing on my 07 Bulldog??
I actually asked about that very question seeing how I have a 07 Bulldog.
Yes and no......:D
Someone from BDM told me,
The new Bulldog has a different triple tree set up with drilled and tapped holes to mount the fairing frame to. However you could put a 2009 Bulldog front end on a 2007 and it should work. Probably have to change the handle bars though since the sweep of the bars are different for fairing clearance.
If you have access to a very good machine shop you might be able to adapt your stock triple trees to take the fairing frame. That might be better than a front end swap. You might still have to change the bars though for fairing clearance.
Yes and no......:D
How about just swapping the triple trees? Are they the same dia. and rake? Or buy a set of trees and get the measurements off them then send them back for return after you get yours drilled and tapped.
Nomad2day
I do not know the answer Alhall....
I only asked a couple of basic questions. Why not just send my triple trees in and let them drill them and send some bars back too with them....
Perhaps all will be made known soon enough. They have not looked at the retro fitting to earlier years.....
I will just have to go by the home factory and let them try it out on my 07 bike to see what it would take....:whoop:
