k9nut
Sorry about the long post. I have posted this problem before but have not found a solution yet. I was hoping some of you could make a suggestion as to the problem.
I have been having an intermittent engine miss since last June. The bike runs great when it is cold. After warming up the exhaust note will start to change to a slight “popping” note at a constant RPM say 70 MPH. After two to three minutes of this the engine will lay down in power and start a “motor boating” sound. If the throttle is opened at this time the engine will pop through the air cleaner a couple of times and then start backfiring very loudly through the exhaust. The engine will also start surging at a constant throttle position. After stopping the bike the engine will idle OK and at this point and I can slowly start moving until just over 2000 RPM and then the engine will lose power and resume backfiring and surging. The engine will not go over 2500 RPM If I continue on the throttle at this point the engine will quit. In June I was able to ride 100 miles or so before the problem occurred. In Oct I was able get to Las Vegas (300+miles) before the problem started. The ride times before having the problem have been getting shorter each time. The last five or six rides I have only been able to ride about 30 miles before the problem occurs. Sometimes the problem will clear after a couple of miles and run fine for a few miles and then start again. Other times I have to shut the bike off for 45 – 60 minutes and then it runs fine for another 40 or so miles.
I have had the bike at 2 different Big Dog Dealers, 1 Big Dog Service center, 1 independent Harley shop and 1 local Chopper shop for a total of 18 weeks and $2500. None have fixed or found the problem. One said it was probably a fuel problem, another thought it was ignition and one said a valve sticking problem. The only thing we all agree on is it is heat related and is not spark plugs. I have one more BDM Dealer to try, Before that I was hoping to get some ideas from this group so I could have a “check list” to at least make sure everything is checked. If I knew the problem I would probably try fixing it my self. Most of the basic stuff like leaks, dirty gas, dirty filters etc have been done so I will not list all that stuff here.
I really do not know where to go with this. Perhaps tear it down and sell the parts on eBay. (Joke)
Thank you for any ideas you can give me. – Gary C
