Need to buy
GoofyTexan
I called Strokers here and Dallas, needing to replace a warped front brake disc for my 2003 pittbull.
300.00 Jesus H. Christ.......
Is there a place where I could get a cheaper one or a use one?
LDO
The Cleaner
Yeah,
make sure those will work on your bike. My 03 has 'floating' rotors so no workie on my ride!:2thumbs:
shovelcowboy
Yeah,
He must not have 'floating' rotors if they are warped. I thought that back in 03 BDM was using some 'harley parts'. If the bolt pattern and diam. are the same and if the caliper width is enough, they still should work (I think).
Shovelcowboy
pig pen
In 03 bdm must have been flip flopping venders. My 03 doesn't have floating rotors either.
Goofy, your wheels were most likely made by RC Components so you might check with them on the disc. Also, Shovelheadkicker on eBay sells a lot of parts from BDM.
My 03 Mastiff had floating rotors.
Tim
Founder
Lifetime Supporting Member
Contact WB Cycles/Nelson here, he sells BDM parts.
BDK9
Big Dog floating front floating rotor on eBay right now. Bids at 31.00. Just search Big Dog Floating Front Brake Rotor. 1 day and 7 hours left as of now.
Kent
