Blue Locktight
Moespeeds
I use red on everything. Every bolt, just red. Blue would definitely not hurt, but if you really don't want it coming loose until you're ready for it to come loose, just use red.
Ratman
May I ask which "Red"? The service manual lists several different ones depending on application. Thanks!
reloaderbmg
OLD DOG
its not that its coming loose, you are tightening down on soft lead terminals that slowly get[ smushed!!!] [now thats tech. shit!]
pig pen
Fuck that I know what your are talking about, mine has come loose more than once. Switched out the lock washer and no more trouble.
actually they are called star washers that are on the battery connections...
chacha
Chaff Your EHC!!
Rhino -- no locktite on the battery! You're trying to get the best electrical connection possible and locktite ain't gonna help. As Gas said, replace the star washer --or go to a split lock waster (I did). :up:
Moe -- you're going to have some fun down the road at some point just using RED! :eek:
BBChopper
Supports 2 Disabled Vets
Yup.
Moespeeds
This is my bike right now. I've never had a problem getting anything apart, so I never saw any reason to use blue!
chacha
Chaff Your EHC!!
More power to ya Moe! I understand your point...if it works for ya, why change !
Loafington
Having trouble with loose battery connection every couple of weeks. Do you guys use locktight?
I hope you're not talking about putting Loctite between the terminal post and the cable. But if you are having trouble with the hardware on the cable end and that keeps coming loose, like the other guys said, a new lockwasher, or get a lock nut. I tend to go with locknuts as much as I can but to each his own.
rhinoevans
lock washer, what is that. Dont have one on the battery connection, so I guess I now know what my problem is!!!! Thanks everyone.
rufroggy
Rhino, I'm having the same problem..and amazingly, I don't have a lock washer either...I just always carry the old faithful crescent wrench but will probably upgrade tothe lock washer TODAY...
