Plastic tube melt possibility?
heems
There is a plastic clear tube that touches some rather hot points of the engine. I have attached a pic below. Do I need to be concerned about it melting at all? It seems to me, for the most part, the tubes and cables are all tucked neatly except this one...
Chopper Dave
SIICK!!!
thats your carb drain line....you shouldn't have a problem...but you can always get a ss sleeve for it and re route it...thats what I did....here is a pic...mine is run towards the front of the motor....
LDO
The Cleaner
Dave,
where did you pick up the ss sleeve for this line?
Is there a post on this already? If so, my apologies to all....:up:
Yeah just use the link Dave put up... its real easy to do.
Replace the old line with some cheap fish tank air line...
