left blinker indicator on
Jdog117
My left blinker indicator came on, it's not blinking it is just constantly on. I checked the lights, they are good. I checked the blinkers, and they are good. I popped the seat off and the LEDs are as follows: looking forward; top row, second from the plug, yellow LED is on; bottom row, sixth red LED from the left is on. What does this mean if anything?
All the lites are lites on that side are ground fault lites. Check your wiring harness for grounds. Mine grounded at the back of the battery as it comes out of the fender. Fix it up and you should have no problem.
I shrink wrapped my wires individually then did it again as one harness. Check here:
Dakotabos
Just asking the questions?
The left blinker is on; or the indicator on your Speedometer?
Is that when the bike is running or just the key on?
EHC indication is that with the bike running or just key on?
Thanks
Jdog117
Thanks for the info. I popped the seat, checked the wiring, and found the rear lighting harness purple wire was rubbing against the frame and causing it to ground. I taped them up, took a test ride and no more indicator.
