Floating Rotors
Cynbahd
Have any of you dissassembled and re-assembled the floating rotors? I found a company that does color chroming, which is incredible process by the way, and I want to re-plate the carriers. Any help is appreicated.
The 10 pins just have C-clips on the back side. I've had to replace mine several times. Just pull them and you can remove the rotor from the carrier.
:2thumbs:
LDO
The Cleaner
Yes,
what Ray said. Did the same thing when I had my wheels chromed.:D
Ray
You have any picture from your floating rotors pls
Thanks
This is about it. You can pull the C-clips off the back of the pins and remove the carrier and have it re=chromed or whatever you want to do with it.
