Vance & Hines Big Radius $350
Mario77746
These were on my bike for 1,000 miles then I switched to the phantom. They are in like new condition with the typical scrapes on the lower pipe from dragging. $350 + shipping.
I'll try to get a few pics posted over the weekend.
Thanks.
Mario77746
Here are some Pics. Again, these pics are practically new and I even took the liberty of scrapping the lower pipe for you....:up:
ALDog
OK, so I have a question. I have an 08 Ridgeback and I talked to V & H because they don't make the 2 into 2 for the 08 Ridgeback. They told me I could use the one for the K-9 and would have to fab a bracket. My father owns a street rod shop so the bracket is no issue. My question is would these work on an 08 Ridgeback or do they not even come close to kicking out far enough from the engine because of the 330 rear tire. Are the flanges fixed or do the pipes rotate in them? If anyone knows the answer I would love to hear it... :job: :cheers:
ALDog
Thanks Gas. My thought was that if the flanges are loose th pipes can be rotated out some to be in line with the rear mounting bracket and leave some clearance. What size back tire does the 05 have, a 250? If so we are talking about 3" difference in tire width or 1.5" difference on the right side. Don't know if they would rotate out that far and still look OK, thoughts?
ALDog
Loaf the 08 RB actually has a 330 which would make it:
250 = 9.8
330 = 12.99 (say 13)
13 - 9.8 = 3.2 or 1.6 a side.
That seems like quite a bit and that it will make the pipes look as if they are turned out more than down. My plan has been to use pipes for an 08 K9 with 300 rear tire and fab my own bracket but the price on these was attractive. I may just say screw it and have Stainless Creations build me a custom set for $800 or $900. Thanks for the input thought because I wasn't sure what size tire the 05 had. :cheers:
ALDog
So Mario, that makes a big difference if the 05 has a 300 rear tire. Then we are only talking a half inch and that's basically what I was planning on with the 08 K9 solution. Do you have the brackets also? Thanks. :)
Loafington
250 = 9.8
Oops, yeah forgot about that. Thanks.
