For us new to this, we're gonna need a little more help...:2thumbs:
The older ones are like the HD model grips pegs and levers.
On the newer bikes, BDM has put on proprietary controls. Meaning, you can only use BDM stuff on them. Some companies make aftermarket pegs and levers but not many, therefore, they're somewhat pricey from what I gather (I have an 03![]()
BDM used thicker bars so HD and aftermarket HD-type controls will not work.
As for pegs, I'm not sure it BDM changed the mounts but I'm pretty sure that it's proprietary stuff as well and you can't just change the pegs. If they changed the frame mounts, you won't be able to change the forward controls either!
If you do a search, you might find threads relating to aftermarket pegs/grips. Also, you can contact our supporting venders to see what's available as well.
LDO sends.
Oh,For us new to this, we're gonna need a little more help...:2thumbs:
Oh,
sorry, I wasn't sure how much help you needed.![]()
I'm don't think anyone here has modified older HD levers to make them (upwards) compatible with the new controls. Sounds like it would take some work. Maybe someone else will chime in with suggestions.
LDO sends.
I can see a little diffrence off hand on the brake lever.The Vision levers are cool but these knife levers are FUKIN WAY COOL!. AND, they will match my paint and the theme Im trying to pull off here. Im gonna waste some money after xmas and see if I can figure out how to mod these things to work.
Our BDM lever for the brake has a small ball hole (very slight) for the piston shaft to sit in.
The HD one is a point.
If I did not just throw out my old 07 hd levers I would have looked them over for you to see the diffrences.
Sorry I can't help more.
But there are harley owners on this forum that may have a HD set.
But I believe the pull on the levers may be diffrent as well.
Yep, looks like the pull is totally diffrent on the clutch.:bang:Looky here for some pics on them..
http://www.bigdogbiker.com/forums/how/2024-how-pull-swap-your-levers.html
