Coming Sooooooon...Winter Mockup
Staffy
Thought I would share...
Thanks to all on the forum, sharing your ideas and input -: :up: :up: ...here's my coil setup - tieing in with the K9 limited paint scheme....
Coil Setup
Coil Setup With Karata 4"
RSD venturi ...ties in well with the wheels
RSD venturi with XXXCarb...some bling...
Hope you enjoy them just as I do...still need to finalize and bolt up, etc...tons of work ahead, its just a mockup...
Staffy
No issues with the RSD intake? There was some discussion earlier about it fitting G carbs.
Yep...needs a bit of work...but again as Gas once told me...if it bolts on it aint custom....:lol: :lol: Actualy very simple - need an adapter kit, a little milling and 2 bolts...hang on will do a How to... also want to see how it performs before we bless the sucker...Looks like it will do well...pulls air not only from the sides but also the front...stay tuned.
bdmridgeback
Low Down Chop Shop
I really like that RSD intake. I have wanted one for the "G" since they came out. I may have to mod one for myself.
Cutter
Looks Great :2thumbs:
I looked at the RSD Venturi as well was told they could not come up with an adapter that would work, decided against playing with it since I couldn't see one to know what I was getting. :2thumbs:
Like the painted coil mount and pin stripng to match :2thumbs:
Staffy
How do you like those pegs? I'm thinking about the same peg/grip style. What cam cover is that? It all looks great!!
THANKS
Both pegs and grips are from Xoprodox. Not sure you see them in the pic's but they have the rubber rings over them (decided on that style over all metal). Solid and G@@D product and if size matters :lol: :lol: this is it..jumbo size 7" and it does make a difference :lol: :lol:
Got spike fork nuts from Jake at lowdownchopshop to match with that, just awesome - he has some GREAT stuff. Finally just ordered the chrome tribal controlls to go with the entire set up....should come together real well...
The cam cover is "stock" came with the '07 K9...
Have fun go for it - you will enjoy them just as I do...winter is great and this is just the begining on the "existing K9" the big surprise is to follow (hint hint)...stay tuned....
Staffy
Staffy
Thanks - like you just had to have the RSD Venturi and goes well with my bike K9 limited edition...did tons of research and finally took the plunge risking it....I do have a HD Fat Boy, so I figured if I can't get it to work I could always slap it on to that...but its all coming together well. Don't believe it sticks out and should be comfortable to ride, will let you know how it perdorms along with the XXX carb....if you are in a hurry just PM me and I will give you the quick load down on what needs to happen - real simple....Thanks again
Looks AWESOME Staffy.
Love the pin striping on the coils. Really takes it up that extra notch.
