Need help diagnosing starter
jbboxer
Symptoms:solonoid clicks, engine tries to crank, battery wires get warm, the wire on the starter looks a bit brittle. I tested the battery and it passes at 320cca. I'll start by testing all my connections. How can I test the starter?
If it is a starter, where do I get one? Will a Harley starter work? Oh yeah, this is an 01 Boxer. Just bought this bike. How do I tell which engine I have? What did BD offer in a Boxer in 01? Thanks for any help!
pig pen
How old is the battery? Do you keep it on a tender? 9 out of 10 times it turns out to be a weak battery.
MARV
if the wires are getting hot you have a loose connection somewhere. also you can take your starter to an alternator shop for a rebuild. mine cost $100.
jbboxer
What about a compression release? Ive read some bikes have them. Do all BD's have them and where is it located?
Rottie
Compression release is usually in the center of the head on top of the rocker boxes. You'll see a rubber like bubble! BigDogs have to stay on battery tenders... They are suggesting interstate batteries now!
stay away from interstate, went through 2 in less than 2 months. supposed to be 320 cca but they are nothing but a re-badged 270 cca yuasa with less power than my 2yr. old original. wouldn't even maintain a decent charge while on the tender full time. will go with big boar when i can. :angry: :angry: :angry:
HD AGM battery for any year softail will work GREAT!!!
Coolbreeze
The neg. cable likes to come loose at the starter mounting bolt. Comp. releases started in 03.
Test the starter= with a heavy gauged wire, jump from the trigger wire too the positive cable @ the starter. Set yourself up so you can just touch the wire too the positive quickly and release it.
BigDogBro1
Made in the USA
I believe these bikes have a standard Negative/Ground type car system meaning the starter is driven by 12v via the +battery post through the starter solenoid. The starters case is the ground path back through the engine/frame to the battery negative post.
Warm fat battery wires:
1. Loose or corroded main 12v feed cable connections.
2. Excessive battery current draw caused by tired starter motor. Brushes wearing out, windings shorting together from vibration etc..
3. Starter solenoid contacts are worn/corroded causing less than full current to the starter.
4. Brittle starter wire from high starter current draw over time.
My two cents!
Coolbreeze
Pig Pen,
Look down the top center of the rockerbox. If you see a bolt head , you can pull those out and install elect. comp. releases. The releases are about $220.
My 03 doesn't have compression release? And I would love to have them on my 107.
Put them in! Your bike was built for them. I guess they just didn't have supply at the time. Your wiring harness is ready to except them. There is a tech note out that on 03's you must use an 02 starter relay.
I installed them in my 03.
roedog
HD Battery works great
Yep Gas, since I installed my new HD battery my Mastiff cranks right over even easier then before with a piece shit interstate battery :job: . I don't even have comp. releases on my 107, shit who has cash for the extra stuff, Ha.
Roedog
bdmridgeback
Low Down Chop Shop
Same here, Went through three Interstate batteries and finally put a Big Boar 350cca battery in it. Zings over like a bitch now!!!!!:2thumbs:
Roedog
Roe... yep, plus they are easy to get.
whitewolf01
starter click
Pull off the little cover on the silnoid, it has three screws. look to see if the wire is burnt through to the contact point. If so, you can usually solder it back togather. Sometimes that works. If not, you may have to replace the starter. You can buy a Spike starter for it. I would suggest a 2.4 starter. Depending on the year, but it may not have compression releases.
