Another trans main shaft problem
k9nut
I took the K-9 in for the 15K service and help with my mis-firing problem last week. The dealer called said they will have to replace the trans main shaft, bearings, and seals. They will know more this week after they finish tearing it down. It was unexpected as there were no shifting or other problems I had noticed. I think someone was keeping a list of main shaft problems so you can add one more. - Gary C
Gary........same here. Mine was already at the shop when it stuck in third gear. They sent it back to the factory and I haven't had a problem since. Good to see there taking care of you. Mine was down a month.
k9nut
Sorry I missed you. I rode over with my brother in law on Thursday and we came back Saturday in the wind. I was very surprised at how well the K-9 handled the 30 mph gusting to 45 wind. Much better than the Harley that was with me. The sand took its toll on the billet, but nothing a little work with Mother's red ball won't fix.
The work is not covered by BDM so not sure if they are going to "take care of me" in the way you mean. I think my check book is going to take a big hit.
Maybe a call to BDM would help. Mine was out of warranty and BDM still covered it. They know they have some issues with some of the transmissions. Good luck
k9nut
Got my Dog back yesterday from the dealer. Cost $1500.00 and took 4 weeks. BDM did not cover any cost as I have 15K+ miles on the bike. :(
Gary C
Nomad2day
Longhair Redneck Geek
K9Nut,
What does the 15k in millage have to do with it? Is the bike out of waranty already?
I thought Baker had a 5 year warranty on the transmissions even though BDM only covered the bikes for 2 years. I saw a post on here about Bakers coverage but not sure if I actually read it though.
Sorry to hear that about the cost. Did you tell BDM to fix it up front?
Glad you are cruising..........:cheers:
k9nut
Nomad2day I am not sure what you mean by "up front". I took the bike in to the dealer for the normal service. Normally I would have done it myself but have been having a problem with ignition cutting out and needed help finding that problem. The dealer found the main shaft bearing/seal problem. They said it would not be covered under warranty (bike 3 years old). After reading some posts here on the forum I called BDM my self. I was told they have helped some people with the problem when the bike is over 2 years when they are lower mileage. I was told a bike with 15K miles is a "ridden" bike and it was normal wear and tear. I talked to the local "bike" shop about doing the work, but they said they might not be able to get the BDM parts. At that point since the bike was in pieces I decided to have the dealer do the re-build of the trans. This is when I told them to fix it. I didn't know about the Baker warranty but I will call them next week and check.
Just to make it clear I do not necessarily feel that BDM should have taken care of the problem. I just asked them because some owners on the forum seem to have gotten help. If BDM had felt it was a common problem due to their design I am sure they would have stepped up and made it right. One thing I have learned in 55+ years of motorcycling is if you ride them they cost money and I have never had a "garage queen".
The only thing is the original miss-firing problem was not fixed so in the end I am going to have to find it myself :)
Nomad2day
Sorry to hear K9nut,
By up front, I meant you told them to fix it either way if it was covered or not...
I do not know how Bakers waranty applies to us seeing how BDM purchased the transmissions from them in bulk I am sure. No one said anything about filling out any waranty cards on the tranny when I purchased the bike so I would guess that should be done by BDM and it should be part of the purchase when you bought the bike. Would not make sense for a OEM to downsize a existing waranty but should pass it to the consumer. I know if you buy a car and a tire goes bad, they pass the problem on to the tire manufacturer to make it right.
Just a thought. The below is from Bakers sight..
Neil
BAKER Drivetrain | The Drivetrain Authority
BAKER LIMITED WARRANTY
BAKER Inc. select transmission assemblies and transmission kits are guaranteed to the original purchaser to be free of manufacturing defects in materials and workmanship for a period of 60 (sixty) months from the date of purchase, or up to 50,000 miles, whichever is sooner. If the product is found by BAKER to be defective, such products will, at the option of BAKER, be replaced or repaired at cost to BAKER.
NOTE:Warranty card must be returned within 45 days of purchase for warranty to be valid.
In the event warranty service is required, the original purchaser must call or write BAKER immediately with the problem. If it is deemed necessary for BAKER to make an evaluation to determine whether the transmission assembly or transmission kit is defective, the entire transmission assembly, whether originally purchased as an assembly or kit, must be properly packaged and returned prepaid to BAKER with a copy of the original invoice of purchase. If after an evaluation has been made by BAKER and a defect in materials and/or workmanship is found, BAKER will, at BAKER’s option, repair or replace the defective part of the assembly.
RETURNS AND EXCHANGES
Any merchandise returned for any reason (exchange, credit or modification) must be accompanies by a Return Goods Authorization (RGA) number or it will be refused. Call BAKER Drivetrain to obtain this number prior to returning goods for any reason. BAKER Drivetrain is not responsible for return shipping charges.
ADDITIONAL WARRANTY PROVISIONS
This limited warranty does not cover labor or other costs or expenses incidental to the repair and or replacement of BAKER products.
This warranty does not apply if one or more of the following situations is judged by BAKER to be relevant: improper installation, accident, modification (including but not limited to use of unauthorized parts),racing, high performance application, mishandling, misapplication,neglect (including but not limited to improper maintenance), or improper repair.
BAKER shall not be liable for any consequential or incidental damages arising out of or in connection with a BAKER transmission assembly, transmission kit, component or part. Consequential damages shall include without limitation, loss of use, income or profit, or losses sustained as the result of injury (including death) to any person or loss of or damage to property.
BAKER transmissions and transmission kits are designed exclusively for use in American V-Twin motorcycles. BAKER shall have no warranty or liability obligation if a BAKER part is used in any other application.
If it is determined that a BAKER transmission assembly has been disassembled during the warranty period for any reason, this limited warranty will no longer apply.
Download a PDF of our transmission warranty card here. Please call 1-800-640-2004 for more details.
k9nut
Thank you for the Baker info Neil. I told the dealer to fix it after I had called BDM and checked with a local bike shop so I did know it would not be covered. It was only $75 over the estimate so all was well. I will contact Baker this week to see if they will do anything. - Ride Safe and often.
Gary C
