INCREASING MY CAM... NEED HELP.
I want to increase the cam on my 04 07 cu in. Can someone tell me what's the largest cam I can go with, without getting into any major motor work.
Gasman, this one's got your name it Buddy.
V
Woods .590 is a good torque cam. While the S&S.600 is a good mid to top end cam. Need to make sure you have springs capable of handling the lift of the cam of your choice and roller tip rocker arms as well.:2thumbs:
lee
before you buy any cam decide what you want it to do and do your research
Redflames02
Whatever you can go without changing the heads. Not sure for your bike, but when i changed the cam on my HD boy did it make a difference. Plus jet kit, high flow air cleaner & the right pipes. May need to change pushrods.
John
Nope... you need to talk to Alhall, Cutter, or Marv.
But you need to find out what you have first... the ONLY way to do that is to check the cam itself. May have to pull it to have a TRUE idea if not printed ont he end of the cam.
Yeah well BDM swore up n down that Alhall came with the 600 and when they pulled it out... NOPE epa 569 cam
