Biggest
stlmikie
I wish I had more money.
What is the biggest cam that I can put in a stock 107 without doing any headwork? Thans guys.
Bocephus05
I would think you could run any "off the shelf" grind cam designed for your engine.You will have to change to stiffer valve springs with big lift cams.As far as "headwork" you shouldnt have to do any port/polish work.I'm new to these engines and dont know what interchanges and all whatnot.On a couple of my atv's we have had custom cams ground from webcams.Had to extend and harden rockers.Every rocker has a limit of "lift" before it runs out of travel (cam lobe tries to push rocker past its limit)then you will gauld everything up and have a big mess (dont ask how I know lol).Also not sure about the valve reliefs on these motors, but that is another factor that will limit the "biggest" cam you can run in terms of lift,duration,and ramp.All that and I still havent answered the question:D .
dogvet
Banned
The old BDM 107's were set up to run up to a .630 lift cam. But I wouldn't recommending just bolting one in. Spring pressures, piston to valve and valve to valve clearance should be verified along with every other potential clearance issue that big cams can create. assume nothing!
