07bigdog
07BIGDOG
Could one of you expert members tell me at what oil pressure trips the oil light to come on? I'm still dealing with low oil pressure at idle. I checked the sending unit. It reads 1 ohm when the wire is unhooked and open circuit when you start the bike. Hook the wire back up and turn the key on. The light comes on. This is telling me that the sending unit is okay. Is it possible that the sending unit is over sensitive or subject to vibration and it is tripping too early? I had 2800 miles before the light started acting up. When the light was coming on tonight, it looked like the oil pressure gauge was reading about 5 psi. The outside temperature was 63 degrees.
