Fibersnake
Banjo Playing PsychoBilly
Okay,
I am putting my stock clutch back together and have a questions and can not seem to find it in the search or the manual. On the Pivot plate that is held on by the 4 bolts (5/16 X 18 X 2") capcrews apProx, it is the plate presses down on the diaphrame spring to the pressure plate, what are the torque of these bolts? If not torque how much do you tighten in down to get the diaprame spring to the proper pressure?
Anyone that has messed with a stock clutch and had it apart, any suggetion would be greatly appreciated. May not be a big thing, but it woudl seem that there should be some sort of torque or measurement to insure that the proper pressure is being applied to the diaphrame against the pressure plate.
Thanks in advance.
Thanks in advance.
