Loafington
Is there an intake manifold out there for 117" S&S engines that have a longer intake runner for a single G?
Glad to hear that extension kit I sold you is still working strong and well!!I would compare it to a car application. Dual plane vs. Single Plane intakes. Dual planes are shorter and cater towards a street car and a broader torque curve and lower hp peak. The single plane is going to be for a more radical set up and drag or track use. Adding the spacer will increase your peak horsepower number and probably at a higher rpm. I see maybe 10 hp on 600-700 hp motors with a 1 inch spacer. I'd change to the S&S long filter first. I did notice a difference above 4500. My dyno showed my engine was struggling for air up top with my mixture getting fat.
Not entirely true. Not all dual plane intakes are low rise, and not all single plane intakes are high rise. The biggest difference between the two, is runner, plenum design and length, not overall height.I would compare it to a car application. Dual plane vs. Single Plane intakes. Dual planes are shorter and cater towards a street car and a broader torque curve and lower hp peak. The single plane is going to be for a more radical set up and drag or track use. Adding the spacer will increase your peak horsepower number and probably at a higher rpm. I see maybe 10 hp on 600-700 hp motors with a 1 inch spacer. I'd change to the S&S long filter first. I did notice a difference above 4500. My dyno showed my engine was struggling for air up top with my mixture getting fat.
Ok, just because you never saw a single plane that was shorter than a dual plane does not mean that they do not exist, they are there, they are available, and that is that. You are correct when you say that there is a straight shot vs. the round about way. As far as "liking" to disagree. I do not like to disagree with anyone for the most part, I actually like to agree, and that leaves more time to do other things. Now, here is where it gets interesting; I do not know everything, but when someone gives information, information of which I do know something about, and I find that information to be inaccurate, I will call that person out, I don't care who it is, so don't take it personal.
Now, tell me how a bigger air cleaner will accomplish the same thing as a manifold spacer does. Explain how a Mikuni provides longer runner length than an S&S shorty style…and I do not know everything, which is why I did ask.
Maybe Loaf... you should not "call that person out" and just try to correct them and tell them why they are incorrect. Just sayin....
Where can I look at the info regarding the filter numbers and Mikuni specifications? Have they been posted here before?There have been some members that have researched the CFM needed at high rpm vs. the air filter cfm rating. At high rpm the stock size is questionable. Adding the S&S extended filter takes it out of the equation. It made a noticable difference onmine. I don't think it will do the same as the longer intake but then you don't have room for the longer air cleaner. I wouldn't want the air cleaner out any farther.
The mikuni setup puts the carb close to parallel to the front head giving it more runner length. Couple here have run them.
