Thank you. Yes, it starts up fine. the idle varies once it is warmed up. We'll try to clean before I consider a replacement.A sitter with gas left in the carb now evaporates, leaves a mess in the carb. That says 3 circuits are needed to even start and idle. So the question is, does it start as if one kick, idles and does not hunt, but steady.
Either NAPA for 12 bucks and 20min soaking in carb dip, or 3 bucks worth of vinegar and wait a few days. All rubber removed of course.
I'd take the challenge of a cleaning before I'd give up to another carb setup. Besides, where are we at with the Y fitting and those rubber rings from head to Y of that intake manifold? Lean pop sputter is air intake there before the carb. Vac acts like E... finds the shortest path.
Can you share the size of your jets, needle and air mixtureI run the Mikuni 48 on my 03 Chopper. It’s the best mod I ever put on my bike. The dog was awakened!! View attachment 97160View attachment 97161
That air cleaner (POINTED), is killing your power. I've proven that, on the DYNO many times.I run the Mikuni 48 on my 03 Chopper. It’s the best mod I ever put on my bike. The dog was awakened!! View attachment 97160View attachment 97161
Going to change it out after I’m settled here in NW ArkansasThat air cleaner (POINTED), is killing your power. I've proven that, on the DYNO many times.![]()
Welcome to the Dog Pound! Congrats on your Ridgeback. Can’t wait to see a picture of your new dog. Cheers to many safe travels!Guys , im net to the forum, but not to the Choppers. I like to switch from S&S E carb to Mikuni Hsr in that case may be 45. This is a very simple carb and i already installed of more than 5 bikes. I will introduce myself in a separate post and will share what i want to change on my 06 Ridgeback that i will pick it up at 28.12. By the way im living in Germany ( Europe )
I know the Mikuni carbs very well. The switch isn't difficult, but it does require some modifications. Once you get your bike, take a picture of the intake area and post it. We have to see which throttle cables it has.Guys , im net to the forum, but not to the Choppers. I like to switch from S&S E carb to Mikuni Hsr in that case may be 45. This is a very simple carb and i already installed of more than 5 bikes. I will introduce myself in a separate post and will share what i want to change on my 06 Ridgeback that i will pick it up at 28.12. By the way im living in Germany ( Europe )
