Kickstand Wedge
SKOGDOG
One of the old ones.
In need of a wedge kickstand spacer for a K9 —they were plentiful some years ago, but seem to have vanished into obscurity (along with 20” Wolf rear tires…) haha. OEM spacers are available everywhere, but the wedge shape ones are not. I know using washers could effect the same result, but that spacer (see below) is so much cooler. I have checked ‘the usual suspects’ without any luck.
Anyone know of a source?
Shredder
Snuffy, thank you for the info. But if I had a wedge I could just reverse it to lean over a bit more. Or just use a couple of washers as previously stated. Do you know how long the stock kickstand is compared to the extended.
Hugh
Snuffy
Hugh
I believe it is 1” difference in the two
