@MrWright may be able to help ya with the extensions? He will be along shortly.Anyone have a Push or Bump seat for 06+ Pitbull? Bike has 2.5” extensions on it. Can’t find any shops in my area to swap back to stock setup so trying the seat route.
It really isn’t hard to do if you have the original shift rod and stuff. Where at in north carolina ? Should be someone on here relatively close enough to do it for you if you lack the ability. Probably wouldn’t cost muchThink you have to mess w shirt linkage and Bleed back brake.
Do you know if you have to bleed the brake?
Only if you disconnect the brake line
This might help uView attachment 141090
