Fuel Tank Rubber Isolator Kit
MossBerg590
Decided to take my tank off ans replace the rubber isolators on the front and the rear rubber mount for the tank. Mine were worn out and made a vibrating squaking noise. I ordered the kit from Bigdogpartskingpin, it comes with 2 polished covers for the front rubber. My question is, do they replace the stock metal bar that connects the two rubber isolators? I seen in the manual that the choppers have that setup but the ridgeback and k9 have the setup i currently have. I will attach the pics of the kits I purchased and a pic of my current setup from the manual. Bike is a 06 Ridgeback
MossBerg590
Its doesn't replace the bar...they are models that have the covers...all you needed was the insulators not the full kit for various models
So why are they listed as working on a 06 Ridgeback? Did some 06 Ridgebacks not have the same setup? Otherwise if it is listed for an 06, and won't work with the #10 cover and the billet covers than idk. I know all I needed was the rubber.
The #10 bar generally does NOT get replaced. If the bar is bad, you prolly have some major tank damage. Its just not a "usual" replacement part. Its a "If it aint broke" kinda thing...... If you just Have to replace it, take it to a local machine shop/machinist and have it duplicated. Its not a complicated part. Eric(who is no longer with HDM) set up the website a few yr back. He coulda made a mistake here n there. Just be thankful we can get ANY parts for these bikes.
MossBerg590
Ok, sounds like I should start a return and just buy the plain rubber isolators since the billet caps won't work with the #10 bar on. Thanks
