2004 Ridgeback - troubling rhythmic clunk
Rich_M
Hi All,
I bought a 2004 Big Dog Ridgeback w/ 4K mi and love it. I put about 800 mi on it so far and everything seemed fine until recently. I noticed in the past couple of weeks a kind of rhythmic clunking coming from the bike. It doesn't show up until about 40 mpg. I checked the primary chain, and it was loose, so I got it back in spec. Oil pressure and temp seem fine. Throttle response feels normal, bike starts up great. The clunk isn't really loud, doesn't occur below 40 mph, but I never noticed it before, so I am concerned.
But I just took a test ride and it's still there. Also, since I am riding, it's hard to pinpoint exactly where it's coming from. I did notice when I was adjusting the primary chain that the compensator housing has a small dent in the lip of the housing (not the sprocket, but the cup on the outside of it), and was wondering A.) is that a problem, i.e., can it damage the bike? and B) What is this part called and can I replace it?
Given the age of the bike, I was going to change the fork oil, too. I thought maybe I was mis-hearing it and it was something with the front end. But to my ears, it sounds like it's coming from underneath the front of the bike. I am open to any ideas/theories you guys may have.
Does the clunk occur when doing anything special? Braking, accelerating, shifting? Start by checking majors. Axels, brakes, forks etc. Ck the triple tree bolt also. Ck the top motor mount bolt. Trans bolts. Ck the VR, make sure it aint loose. As far as the compensator is concerned, the dent is a normal manufacturing mark. If it goes south, you will hear a whine like an old Singer sewing machine.
Rich_M
Shifts like butter, no worries getting it into N. I had a sneaking suspicion it was the front end. I don’t think it’s the brake.
Thanks man. It seems proportional to the rpm, but not directly. In other words, it seems to be speed related. I think you’re onto something because I think I’m feeling it in the front end. But I’ll go over the items you suggested and reply back.
Pay close attention to the triple tree bolt. Mine was loose on an Arkansas trip. Got home n my new front tire was trashed. I could feel a pulsing vibration around 70 mph but never thought it was that loose. Took a buddy looking at to figure it out.
Rich_M
I figured out the clunk. Steering neck bearings. I guess I just got lucky, it didn't do this 800 mi ago. I can feel the notching and noticed noticed a slight amount of back and forth play in the forks. Anyone got any hot tips for replacing the neck bearings? Looks like a PIA.
Still love my bike, but want to get it ready for Winter (riding season in AZ).
Glad you got that figured out before things took an ugly turn. They aint hard to change. Helpful to have extra hands tho. You can hang the handle bars from the ceiling to mitigate total deconstruction. Still a pia. Getting the races changed can be a challenge in and of itself. Good luck!
DudeInSneakers
I wouldn’t assume the compensator is the cause just because of that small dent, especially if the sprocket itself looks undamaged.
Since the clunk only shows up above about 40 mph, I’d check anything that changes with road speed before tearing deeper into the primary — front wheel bearings, rotor/caliper hardware, steering head bearings, axle, and engine/trans mounts.
With the primary open, I’d also inspect the compensator assembly carefully for witness marks or anything that looks like it has been contacting the cover. If that outer cup is actually rubbing, there should usually be some visible evidence.
The fact that adjusting the primary chain didn’t change the noise makes me think the loose chain may have been a separate issue.
I’d avoid riding it much until you can reproduce or locate the clunk, especially if there’s any chance it’s coming from the front end.
He fixed the problem. Neck bearings.
