I'm assuming when it turns over it starts. Does it? Hopefully you mean clicking noise because clunking noise could mean something way more serious. I don't think your bike has compression releases which do click at startup. If indeed it is a clicking noise get a stethoscope and try to locate the sound . Could be the starter solenoid.Bike Has New Battery All Ways ON TRICKLE CHARGE TAKE CHARGER OFF BIKE WILL TURN OVER BUT THEN ALL I WILL GET IS A CLUNKING NOIS UNDER THE DASH. PUT CHARGER BACK ON FOR FIVE TO TEN MINUTES TAKE CHARGER OFF STARTER ENGAGES AND MOTOR TURNS OVER.THANKS FOR THE HELP.
Post a picture of what you’re talking about. I’m assuming you talking about the Thunderheart ECM between the tanks? Sure wish I could hear it. Clunking noise…. Scratching my head on that one. Is this what you’re referring to?THE NOISE IS COMING FROM THE COMPUTER BOARD UNDER THE TANK DASH. ALL CABLES ARE CLEAN AND TIGHT.
BATTERY IS FULLY CHARGED. AND YES IT STARTS.
Computer boards (EHC) do not make noise unless they are on fire and sizzlingTHE NOISE IS COMING FROM THE COMPUTER BOARD UNDER THE TANK DASH. ALL CABLES ARE CLEAN AND TIGHT.
Replace your starter or your starter solenoid.I HAVE TO APOLOGIZE THE NOISE IS COMING FROM THE SOLENOID. THE NOISE SOUNDS MORE LIKE A LIGHT CLUNK THEN A CLICK. WHEN I TAKE CHARGER OFF BIKE WILL TURN OVER THEN THE LIGHT CLUNK NOISE PUT CHARGER BAKE ON WAITE FIVE TO TEN MINUTES BIKE TURNS OVER GOOD THEN STARTS.
If your battery load test comes back good check your starter solenoid contacts for burns or damage. Consider a rebuild.I HAVE TO APOLOGIZE THE NOISE IS COMING FROM THE SOLENOID. THE NOISE SOUNDS MORE LIKE A LIGHT CLUNK THEN A CLICK. WHEN I TAKE CHARGER OFF BIKE WILL TURN OVER THEN THE LIGHT CLUNK NOISE PUT CHARGER BAKE ON WAIT FIVE TO TEN MINUTES BIKE TURNS OVER GOOD THEN STARTS.
www.bigdogpartskingpin.com
Take a picture and post it.Hello everyone I taped on the ECM and bike starts every time now removed plugs from ECM and put Dielectric grease all good. But have new problem left rear shock bolt broke off in frame does anyone know a way to get it out. I don’t understand bike has only 5000 miles on it bolts must be very cheap
Attach filesnever post a pitcher how do you do it.
Welcome to the club)))Hello everyone I taped on the ECM and bike starts every time now removed plugs from ECM and put Dielectric grease all good. But have new problem left rear shock bolt broke off in frame does anyone know a way to get it out. I don’t understand bike has only 5000 miles on it bolts must be very cheap
