Russ Magyar
I have a 2007 Big Dog Chopper, It had a dead battery and I replaced it with a new battery, When I turn the key on the the horn sounds continuously, Is there a reset for this?
Hmmmm. That’s usually not a good sign. Does your headlight come on when you turn on the key? What battery did you install? Exactly? Take a picture of the EHC under the seat near where the battery is. Post it hereI have a 2007 Big Dog Chopper, It had a dead battery and I replaced it with a new battery, When I turn the key on the the horn sounds continuously, Is there a reset for this?
The Head Light does not come on and no lights on the EHC light up.Hmmmm. That’s usually not a good sign. Does your headlight come on when you turn on the key? What battery did you install? Exactly? Take a picture of the EHC under the seat near where the battery is. Post it here
Thank you.Which battery did you put in? These bikes are kinda picky. A Deka EXT20L or better is recommended. That being said, Welcome from Kansas.
Thank you from Colorado!Yeah check the connections as stated. I’m afraid I am going to have to agree with Knothead. If your battery is good & everything is connected correctly when you turn the key on the headlight should be the first thing to power up and the speedometer. If they aren’t it’s a good guess that the EHC has taken a dump. I’m pretty sure Curtis at wildsteedworx.com can test it for you. Also he sells the best replacement EHC available as Knott mentioned. Good luck & keep us posted! Oh and Welcome from Florida!
Your battery should read approx 12.8 vdc. The horn blowing is not unusual when the battery is not up to snuff. Don't just look at your connections. Pull them and clean them and of course be sure to replace them to their original positions. Also make sure you haven't left any off (they like to hide). A new battery does not always mean its good, have it load tested to be sure it's not faulty. The EHC on these bikes can be very sensitive so be cautious when disconnecting and reconnecting. Always disconnect the NEG (-) side first and then the POS (+)side. When reconnecting do the exact opposite, connect the POS side first and then lastly the NEG side.I have a 2007 Big Dog Chopper, It had a dead battery and I replaced it with a new battery, When I turn the key on the the horn sounds continuously, Is there a reset for this?
Thank you for the advice, I probably won't get a chance to work on it till this weekend. I'll let you all know how it's going.Your battery should read approx 12.8 vdc. The horn blowing is not unusual when the battery is not up to snuff. Don't just look at your connections. Pull them and clean them and of course be sure to replace them to their original positions. Also make sure you haven't left any off (they like to hide). A new battery does not always mean its good, have it load tested to be sure it's not faulty. The EHC on these bikes can be very sensitive so be cautious when disconnecting and reconnecting. Always disconnect the NEG (-) side first and then the POS (+)side. When reconnecting do the exact opposite, connect the POS side first and then lastly the NEG side.
When you eventually get the bike running check to see the VR is working properly. It should be pushing approx 14 vdc but not more than 14.5 vdc. . Also it is a good policy to put a CB or Fuse between the battery and the EHC to protect it from a shorting battery. The stock bike only has a CB between the VR and Battery in order to protect the battery from a VR short or Overcurrent. The EHC would also be protected from the VR but if the battery shorts out ( and they do ) the EHC will smoke right along with it.
Good Luck
