Yeah Yeah!good to hear about Big Dog as usual doing the right thing. THANKS Puppy Farm.
:2thumbs:Yeah Yeah!good to hear about Big Dog as usual doing the right thing. THANKS Puppy Farm.
:2thumbs:After inspecting the clutch assy. at the dealer, I was told the nut had loosened & the above task was completed. Took the bike for another test ride & 4th gear still slips! All the other gears are fine. Owner of the dealership is contacting BDM to see what gives. We'll see.No biggie pull your primary cover take the 4 bolts in the diaphram spring out and you will find a loose nut it has reverse threads. Clean it with break clean and retorque to 100 ft pds with red loctite reassemble. refill primary fluid and for sure check trans fluid!
Mine did the same pulled the trans apart and the 4/6 shift fork was bad:bang:After inspecting the clutch assy. at the dealer, I was told the nut had loosened & the above task was completed. Took the bike for another test ride & 4th gear still slips! All the other gears are fine. Owner of the dealership is contacting BDM to see what gives. We'll see.![]()
House did you ever get it back on the road again.Mine did the same pulled the trans apart and the 4/6 shift fork was bad:bang:
House,Mine did the same pulled the trans apart and the 4/6 shift fork was bad:bang:
