gas tank
edward
I have a 2000 bigdog bulldog need to remove tank liner has any one done this before and what did they use to remove the liner plus what they use to plug the gas cap hole to keep chemical from getting on paint
Remember, anything strong enough to remove the liner, will remove the paint on the out side. Luckily, all the ones I've done, were going to be painted afterwards. Do a search on here, there is a thread that mentions the name of a company that does it professedly
Snuffy
what I need is a plug to go in filler neck to keep the chemical from leaking out and eating the paint I thought someone here would know where I can find one
Look at plumbing stuff. I know they make rubber plugs for different size pipes that expand to stop water under pressure so I’m sure it would work for that. Should be something along those lines that will work
Shot in the dark but try a craft store. Hobby Lobby type places. They may have some larger sized rubber/cork plugs? Or shove a rag in the hole and tape the heck outta the fill hole? Id have the entire tank taped if I wasnt gonna repaint.
Chong
U-238
I had one i taped off and then painted over that with liquid mask .. Filled tank with acetone. Well some seeped out of pitcock and the paper masking tape wicked it up... Damaged some paint on lower edge of tank .
Bummer .. Further pain was acetone didn't touch the liner .. it set for two days :(
I'd send it out .. lot cheaper then new paint.
A couple well respected people on this forum suggested not trying what I did. And to just run it and flush as needed.. Poblem i was having was bad liner and a pin hole leak in one of the tank mount pockets. And the liner kit i purchased claimed it would bridge such issues and solve the leak. I had tried sealers, epoxy etc.
Here is a place that does it.
Mickmorris
Well Known Member
I had one i taped off and the painted over that with liquid mask .. Filled tank with acetone. Well some seeped out of pitcock and the paper masking tape wicked it up... Damaged some paint on lower edge of tank .
A couple well respected people on this forum suggested not trying what I did. And to just run it and flush as needed.. Only problem i was having was a pin hole leak in one of the tank mount pockets. And the liner kit i purchased claimed it would span such issues and solve the leak. I had tried sealers, epoxy etc.
:agree:
Ugh, I need to do this to mine too. Last time I fooled with the bike, like 2 years ago, something in the tank (probably a tiny chunk of liner) made it past the petcock filter and down into my carb and jammed up one of my jets. After that, it sat a little longer and was transported to my parent's house to sleep for a while and now it's here at my house where I can tinker with it. It's probably been sitting 2 years almost since it ran last with little to no fuel in the tank, so I know it needs a good cleaning and lining.
Good luck in your tank sealing quest, brother.
Mickmorris
Well Known Member
Wow. 2 years. Sad. Good luck with getting it running again.
