New Soft Pull Performance Clutch Kit
KDF
Anyone tried this yet?
BDM Soft Pull Performance Clutch Kit:
Is your bikes stock clutch lever leaving you a little pumped? Do you want a performance pull that feels soft and smooth? Then its time for you to upgrade! Big Dog Motorcycles new soft-pull clutch system is standard on all 2008 models, and is now offered for your 2005 to 2007 model Big Dog. This innovative new product will reduce the effort of your stock clutch lever by an amazing 25%, reducing rider fatigue. Ride longer and more comfortably with your new soft-pull clutch system, available now through Big Dog Motorcycles. [Part No. 123-000017-00]
I have no idea what it costs... but would be worth it after lots of stop and go clutch action on my '06 Pit.
KDF
Dakotabos
just have to make those fingers stronger :job:
I have rode a long ways on trips and I never say after the ride WHEW my fingers are tired:roll:
Give me a seat that doesnt wear my a$$ out
:up:
toomanybikes
not enough time 4 riding
I paid $387 installed for mine (2 hours labor, Soft Pull clutch kit ($220) and miscellaneous parts and shop supplies).
The pull is extremely light and takes some time to get used to. I haven't tried it in stop and go traffic yet.
KDF
:up:
This would not be a problem if the clutch was on the right side... :roll:
KDF
Shredder
I'm told the kit is $250 plus labor. I don't understand why anybody would do this when you can get a better, softer pulling clutch from Bandit for $300. Not even close in my opinion or experience.
Shredder
Dakotabos
Ya gotta switch hit :roll: :roll: :roll:
Hope you dont have to use your front brake much you would go flying over your handle bars :roll: :roll: :roll:
KDF
toomanybikes
Shredder
My Mastiff was in the shop getting the EHC replaced at the time, so why not take advantage of the down time?
lee
Shredder
I totally agree although whether the pull is softer depends on how you set it up. Mine is a lot harder with my Bandit set up with 2 shims on each spring
Cutter
I was told that the BDM soft pull had "slip" built into to it... Softer Springs
I didn't really look into it at all, and was also told that I would "really feel the difference down low" with torque cones. :job:
pathfinder
All the 08s have the soft pull clutch, you can go by and check them out at the showroom - of course, that could lead to wanting to buy an 08 - be carefull!
I would like to do this this fall - I have wrist/elbow conditions and the softer pull would make a big difference in my ride.
drummin777
I have only had my 06 Pit for a week and a half, I have put almost 1000 miles on it already. Anyway, the clutch is wearing my ass out. Is there any adjustments that can be made on the stock clutch to ease up the lever?
lee
not really - just make sure you keep it properly adjusted and regularly lubed
