Drive Pully Corrosion
82ndAirborne
I looked up the product you (Jersey Mike) suggested 'Cerakote'. Seems to be perfect for Coating a corroded transmission 34-Tooth drive gear. They offer a selection of colors and also air or oven dry. I'm going to get the Matte Black - Oven Dry version. One user reported that you could hit a treated part with a wrench...damaging the wrench but leaving the part unblemished!
While looking for a replacement gear I found a 32-Tooth Short Belt Kit at Barnes Performance. I went ahead and ordered the kit because of the performance upgrade it offers. I'll clean up the 34-Tooth gear, treat it with Cerakote, and keep it as my spare. The rep at Barnes Performance told me that if I had a new belt already (not stretched), I do, then I can still use it with the 32-Tooth gear so I didn't order the shorter belt. However, since it's alot of work pulling everything apart to replace a belt I've decided to order the short belt and know that I have plenty of tolerance left for future adjustments.
I also ordered an Easy-Pull Clutch Ball & Ramp. I'm a little older now and when I'm caught in slow traffic going from 1st to Neutral again and again...gets a little tough on my hand. This kit reports a 45% reduction in pull.
Mickmorris
Well Known Member
Andrew wouldn’t steer you wrong. All good stuff from him right there. Sounds like you are taking all the right steps! Barnes Performance Cycles is a solid BigDog & AIH parts & Service Center.
