2005 Chopper
'05 117 in with TP rocker boxes. Just change the oil. Took her out for a 30 mile ride today. She seemed to run great. When I got home the idle was kind of high so I was messing with it all of a sudden starts running rough and then it starts blowing smoke and I mean a lot of it first out of the rear pipe then out of both then oil's coming out of the tailpipe and it's black oil not fresh. Took off the return from the oil filter and it's pumping. The oil was a little low I start putting oil in it and it sucked up a full quart. Like it pumped it in the motor but it all ain't coming back like maybe it's not draining from The Rocker boxes. After it sat for a while as I was checking the oil return line checking the screen in the oil pump which was clean. Turn it over without the plugs in it all that trying to check oil flow. And I started it back up and it seemed to run fine for maybe 8 Seconds going to start blowing oil smoke out the pipe again. Any advice what to look for next?
