In need a a rear v&v big radius pipe
Jersey Big Mike
100K mile club
for a K-9
When I returned home from the Farm, I had lost an exhaust stud (mid trip back I notice boyh nuts were gone, replaced one nad realized bottom stud was missing as well.
Took it off today to replace studs and noticed that the large ring on the end of the pipe that goes into the head that is head by the clip then the metal bracket was missing.
I don't see any evidence of it or the clip ring. If the part is there its now welded to the head -- will have to measure anoure head to see if I need to gently grind it out. or if ther eis enough space for new gasket and pipe to seal well.
Any tricks for removing the baffle -- seems to be stuck pretty good in the pipe.
Jersey Big Mike
100K mile club
I ordered a new rear pipe from V&H yesterday -- 4-6 weeks as it custom order.
Going to hijack the V&H fromthe other K-9 (that is being worked on) till it comes in. Just need to get a slide hammer today to move around some baffles as I don't want to try doing a mix of baffle styles. ie one normal and one aftermarket quiet.
