2000 pro sport
Anyone have one of these Kenny Boyce framed bikes I’m new to the big dog world, just wondering if anyone knows any common issues,is there a service manual online or for sale anywhere? Right now I’m dealing with trying to find a replacement starter but I found the bike for 3k rode fine after buying it I choked the bike and it died and the starter gave out and wouldn’t engage so it’s a bit more of a project than I’d like but here we are.
nvcollins
'08 Mastiff
Hello and welcome from Southwestern Virginia Highlands. I have no experience with that model. I'm sure someone will get you the help you need. Good luck with the bike.
Sent from my SM-S906U using Tapatalk
Mickmorris
Well Known Member
Welcome to the Dog Pound. You can most likely get a starter for that at JP Cycles. They aren’t cheap. You could also try rebuilding the starter you have. Where in Melbourne are you located?
:cheers: :chopper:
Mickmorris
Well Known Member
:cheers: :chopper:
I’m as stubborn as a mule so I bought a used one from bone yard off aurora rd southern v twin gave the starter their seal of approval and I’m working on going back in with it now
Mickmorris
Well Known Member
Man oh man was this job a bitch and a half I had to cut off the two bolts on the back of the tank
Yeah that’s tight quarters. Oil tank & lines right in the way for sure. Git ‘er Done! I do have the ‘94/‘04 Service Manual. If there is anything particular you need information on lmk and I’ll see what I can find for you.
:oldthumbsup: :cheers::chopper:
Mickmorris
Well Known Member
Any instructions in getting the tank back in I think my starter has a clearance issue with the random softail starter
Can you post a picture. Where is the clearance issue? With the line connections? Should have plenty of clearance between them…
I got it then yeah my issue. I don’t know if it was because it’s a softail starter and the bike needs an FXR or what but I got it all together. Got run and grab a hardware kit real quick for the battery and then I should be good to fire it up. See what happens.
Clearance issues was the bottom of the pan and the top of the starter, the. I put the positive starter cable on improperly and had to loosen it 1/8 of a turn with my hand jammed under the oil tank and the top of the starter motor. Looking forward to doing the carbs and getting to rip this thing.
