ANYONE KNOW WHAT THIS INDICATES???
Mikeinjersey
So
update -i cleaned and reapplied dielectric. Fired right up. I tuned off, fired it up again. Bolted the ehc back to its mounting and tried to fire again. Nothing but flashing blinkers. All blinkers flash but the back left. Not sure why it would fire up 2 times then not again. Makes absolutely no sense
Did you have your battery load tested? Did you clean and tighten the ground side of the battery to frame connection? When you get the bike started check to see that your charging system is working producing approx 14 + volts but not more than 14.5.
Little-Boo
The problem as several have pointed out is that the battery may be the problem. We went thru this about 10 years or so ago and some of us took to heart what was being suggested so we went for the fix hoping these guys were right. Back than this Dogs were ridden long distances and Raywood was one of them that put lots of miles on his chopper, so he got in on the conversation. Since I applied what they suggested I have not had any issues with that aspect.
Here is the Issue and it may not be your issue, but it covers lots of BIGDOGS owned by Big Ridders. Take the seat off and look at the back side of the seat and see how thin that felt cover is. Under that felt cover sits a metal pan which forms the seat. The seat felt cover is glued to the underside of the seat pan with 3 M spray glue and that shit is so thin that it gets cut by the screws holding the battery cable on to the battery and could be shorting out your battery. When you go out and hit a bump and the bump kills the bike you blame it on the bump on the road.
I went to the auto supply store as suggested by my friend (May he rest in Peace) Mr. Ray Atwood told me and others to buy the rubber drawer inserts, or liners that are used in toolboxes. Just buy one and a can of spray 3-M Glue, (1) peel the felt cover off the area where the post may come in contact with the battery post screws and cut two squares about 2 inches and pile them on, they are self-adhesive and stick well to the seat pan which is all metal. (2) after you have done that to both sides of the seat felt cover spray 3-m Glue on the back side and glue it back on.
If that doesn't work for some of you, check your rear fender wire harness and make sure. there are not exposed wires rubbing against the inside of the fender or connector.
Good Luck
flcmcya
Just to add info to this thread.
I cleaned and tightened the ground to my starter.... removed the two EHC plugs...which looked pretty cruddy, ....cleaned , greased around the edge..... and carefully tightened all screws which may have been loose to begin with.
Bam! ....started twice last night and again this morning with no issues.... thanks to those people throwing out suggestions.
Fingers crossed!
Mikeinjersey
Fingers crossed!
These bikes need fully charged and healthy batteries. When your bike is running read the battery for approx 14vdc but not more than 14.6 vdc. If it's charging well have the battery load tested anyway to make sure it's in good shape. If your battery is old, more than 3 years replace it . Some will get more years but it's not worth the aggravation.
Fingers crossed!
Glad ya got it sorted out n running. Now....RIDE!
