Help please
Jakevan1390
I found a primary cover set on eBay that came off of a 2006 pitbull with a 300 rear, will that fit my 2005 ridgeback with a 300? Are they the same offset? Thank you in advance.
Mickmorris
Well Known Member
I would think they would be the same. If you pull your outer cover it should be stamped inside with the offset as I recall.
Jersey Big Mike
100K mile club
I can only tell you that the inner primary on my K9 is 2" and the Bulldog is 2 7/8" ask the right questions before you buy.
Pitbull to ridgeback is a little more similar (rigid to rigid) than the k-9 to bulldog but you really need to know the offset on both bikes.
I'm pretty certain the oter primary cover would fit just fine -- do you need to change the inner? You could just sell it off. Just a thought.
Mickmorris
Well Known Member
I bought a set off of a pitbull, both inner and outer, I’m hoping they are the same. I spoke with Knothead and he seems to believe they are the same
That’s exactly who I would call to. I think you should be good with ‘06 pitbull on ‘05 ridgeback.
