RILUSI
Hey all.
If anyone can help I would appreciate it .
I have a 2006 K-9 with the Gen II RIP wiring kit (been on bike for years). I am going to try to catch you all up with what I have done so far.
I recently rebuilt the top end.. Bike fired right up to heat cycle the motor... No problems.
Then I realized that my front brake lever was not triggering the brake lights. I pulled the handlebar control and found that I broke the brake light connector on the circuit board when I was just in there. I soldered the plug back in place.. put back together.
Brake lights now work both front and rear--- bike runs fine. I am feeling pretty cocky!
The next day I have an on & off spark issue... as in the bike will fire up some times and other times it will not.
Now I have no spark all the time. I am checking spark the old fashion way with both spark plugs grounded.
I pulled the handlebar control apart and unplugged the board to eliminate that as a suspect. Was thinking I messed up the run button or ?
Now I am manually triggering each of the wires with the ground (black) wire on the handlebar plug.
Everything works as it should when triggered. (Brake - Turn -Run - Off -Start)
When I trigger the red (Run) wire the red light lights on the module. When I trigger green (Start) wire it cranks over and the blue and yellow lights flash.
So to me everything is passing the tests.
I do have power at all 3 of the coil wires (check with a 12v test light). That doesn't seem correct.??
I tried a different coil just for fun. No change.
So...... if the red light lights when the key switch is on and the run wire is triggered as well as the blue and yellow flash when rolling over I am leaning towards the crank sensor. Is that a good assumption? Can I check the crank sensor? New one is a bit expensive to just buy and try.
I pulled the crank sensor and inspected the wiring .. it visually appears fine..
Is there something else I should check or try?
Thank You in advance,
