mittens
Rear jug head gasket is leaking some. Never had motor apart before. I have the primary & rebuilt the trans, & everything else on-the bike I have. So here we go. Ordered top end gasket set, valve seals, rocker box gasket set, new boots for compression releases, & a cam cover gasket from Curtis/ WSW. I plan to pull it to see if the factory 520 EPA cam is still in there, or has it been swapped before. If stock will go with a .600 cam while I am here. I want to give everything a good cleaning & polishing while it's apart. I take lots of pics of everything I do so figured why not start a thread of progress. Maybe someone will find it useful/ learning tool. I know pics help me. I know I will have my own questions as I go too.
Today had to replace the China motor on car lift, got my 66 back out the way. Then put bike on lift, got it down to the rocker boxes. Carb, intake manifold, jugs, heads all need polishing. Bike ran great just wanted to address leak & cleaning. Plan to clean valves & top of pistons everything I can get to.
